Up Topic Welding Industry / General Welding Discussion / AC square wave SAW
- - By rshanks (**) Date 08-04-2010 18:46
Needing some advice, I'm running or trying to produce a good weldment , AC squarewave, constant current , Joint Geometry 1/4" a572-50, square groove, 1/16 root (sheared edge) ,3/8" back up bar, Parameters 550 amp, 34v, 40hz, 40% balance, 20% + offset @ 24 ipm. Results 3/32" reinforcement, 7/16 weld face width, penetration marginal at best 1/16 " into backing . Problem inconsistent at toes of root incomplete fushion. Running 3/32" wire, Do to root's running up to 3/16" it will be hard to go to a smaller dia.??????
Parent - - By Sunset Date 08-05-2010 00:57
PM sent
Parent - - By 803056 (*****) Date 08-06-2010 00:13
Run it with DCEP.
Parent - By js55 (*****) Date 08-07-2010 16:41
IMO Al hit this one dead on. You have equipment overkill. Also, with a square groove you need, at least in my experience, a grooved backing to get the metal to flow underneath the toe and get good consistent fusion. It doesn't take much, but it can sure end some headaches.
