Looking at the parameters shown on ESAB's site for the 5/32" rod: 100-145amps A/C or D/C for the Flat position(1F)
I'm a rookie when it comes to using this rod, but there is no way that I can get the arc started and keep it lit down this low with A/C or D/C...I can long arc it and keep it going, but just barely...and the material isn't filling in behind to where I can even build a puddle....way too cold, and what material that is being placed is blue and straw colored.
I pushed the parameters aside and set it up around 180amps DC- and it starts and runs easy and smooth, lays a nice silver colored 1/4" fillet weld with a decent profile. I'm going to let this cool and saw it up/etch it after lunch to see what the root looks like.
Welding with excessive amperage will overheat the flux covering and cause the covering to crack. It will not improve the fusion in the root.
Try depositing a fillet weld in the corner between two 1/2 inch plates (a T-joint). Make sure the corners of the 1/2 inch plates are square cut (saw cut is best) and root opening is tight. Check to see if you have fusion to the root when you fracture the fillet weld.
Al, It sure doesn't act like excessive amperage when I'm welding. Arc is nice and smooth, no spatter. let me see if I can post up a pic of the T-joint that I welded earlier.
Everything stretched as I bent it over and it finally gave up tearing away the basemetal of the vertical plate with the weld still in tact. It tore 1/8 to 3/16 away from the weld. Root didn't let go, so I couldn't see any LOF or line of slag along that part.
I'll go look through the scrap and see if I can find it....
looks acceptable to me, maybe a typo on ESAB's end? Ive had it before whereI contected them becasue soemtihng didnt make sense and sure enough it was a typo.
I've worked with several contractors qualifying their welders using fillet break tests for dissimilar metals using E309-X. The only 309 electrode that managed to obtain fusion to the root and that was the E3XX-15.
Al...dumby me. I went over on another machine and set up again. Guess what? That machine ran totally different, actually ran within the mfg's recommendations and was fairly smooth on A/C, but it was still the smoothest on DC- around 140amps. I need to look into that first machine and see what's up.
Glad I read Your last post before posting Myself. I was going to ask if that was measured amperage, or just what the machine was set at. I know You are a sharp cookie, and see that You figured it out Yourself.
LOL...Dave no, I'm not the sharpest knife in the drawer by no means....but I should have known better and knew when I was welding that far above the mfg's recommnedations and the rod wasn't glowing red or bending over in submission that something was amiss with the machine.
