Up Topic Welding Industry / ASME Codes / ASME B31 Case
- - By john8790 Date 08-17-2010 04:57
Dear All,
ASME B31.1, 1995Ed. thru 1997Add. shall be applied to our piping construction.
ASME B31 case 170 was approved on march 1999.
Question)
Can we use the case 170 to our project?
Please expalin with example in reference to ASME B31.1
Thanks in advance.
John8790
Parent - By MBSims (****) Date 08-17-2010 11:32
Use of Code Cases usually requires approval from the design engineer or owner, since they are alternative requirements.  If your design engineer or owner approves use of the Case, I see no reason you can't use a Code Case that was issued after the specified edition and addenda, provided there are no words in the Case stating it only applies to a specific edition/addenda.
