Mr. Jones, a groove that is too large will require more weld metal, it can affect the HAZ area and size, it will cost more in labor and material. A groove weld that is too small will not allow access for proper welding techniques to be applied. I am certain there are other things but at the moment I cannot think of them.
Mike Sherman
Shermans Welding
A decrease in groove angle can also result in a joint configuration with a high depth to width ratio. Depending on the configuration, base metal, joint restraint, and process, these can be more prone to cracking/tearing in the weld metal at the centerline.
Have a nice day
Gerald Austin
Iuka, Miss.
Rory,
Rajones,
I think your QA system is more than adequate, as it is going above and beyond the AWS D1.1 code, since qualification of a groove weld qualifies for all AWS prequalified joint details without further testing. I'm not sure off the top of my head what is required for D1.2 though, as I don't have one currently.
However, the groove dimensions have a lot more to do with welder technique than weld metal properties. On the mild steel you are welding, you would have to change your perameters significantly in order to affect the properties of the joint with perhaps the exception of impact toughness, if that is one of your requirements. Additionally, if you are using AWS prequalified groove weld dimensions, it has already been determined by AWS that any variation in the quality of the joint will be minimal enough that it would not be worth the effort of requalification. That is why they are prequlified joints. I think the macroetch test is not unreasonable amount of extra work, while also being a good choice, as it will show any incomplete fusion, or slag inclusions that could develop due to changes in welder technique from the different joint geometry. As far as the aluminum goes, again, if you are staying within the allowable perameters of the D1.2 code, you shouldn't have a problem, as the limiting strength in aluminum welds is in the heat affected zone. Since D1.2 limits the perameters that effect the HAZ, joint geometry should have little effect. Again, I think that the macro-etch is an even better test for the aluminum, as welder technique is more critical on aluminum than mild steel.
