So, just because the code allows undercut to be repaired in the downhill progression, doesn't mean a welder who has not qualified to a proper WPS that has been tested through the PQR process can just go over the undercut to repair it. He would have to go over it uphill or in what ever position he is qualified to with a prequalified WPS.
Bottom line of the OP's question though, IMHO, previous posts are correct that a vertical uphill qualified welder is not qualified to weld vertical with a downhill progression. He must re qualify and that will be a totally different test to get the PQR, WPS, and then be qualified.
Thanks for sharing your information from the committee Al. Gives a very official meaning to the application of this question.
Have a Great Day, Brent
