Question, has anyone welded, GTAW aluminum with 100% nitrogen? If so what were the results? BTW, There is an active gas called mizone/myzone or some such name that has a percentage of nitrogen with the balance argon. 2nd question what is the ratio of argon nitrogen in the mizone? The tout is an argon nitrogen blend reduces ozone?
