Any one of the other processes mentioned could do the job, but the OP already is using FCAW and is seeking to improve production rates... I would tend to agree with Larry's suggestions as well as Jeff's, yet there is simply not enough information being shown by the OP's query to really narrow down the best options available in order to indeed make an optimal fit for the OP's specific application... What is the intended service of these vessels??? This is the sort of info we need to have before we can give any assistance to the OP.
More information needs to be revealed about the specific application in order to be truly helpful such as whether or not the joint is PJP or CJP... Whether or not it's a groove or fillet weld and what specific joint configuration is being welded together. There's simply not enough info given by the OP to give informed advice that is specific to the OP's application...
I know, I know I sound like a broken record, but I don't believe I'm incorrect here in emphasizing my point regarding the problem with this query. ;)
