Hi:
I've found one of these used for a decent price. It's a bit larger than what I'm was looking for (400 lbs, in comparison to an ESAB Heliarc 161 AC/DC, Miller Syncrowave 180SD, Lincoln SquareWave 175 Pro, Miller EconoTIG). Anyone know how one of these would compare to the above list? I gather this welder is pretty old (which is not necessarily an issue, unless parts would be a problem). Can anyone advise?
Regards,
Dave
AIRCO 250 HELIWELDER V WELDER TIG/STICK AC/DC CC TIG (GTAW) STICK (SMAW)
INPUT POWER IS 200/230/460 VOLTS SINGLE PHASE WELD RANGE 5-310AMPS
UNIT WEIGHT 400 LBS UNIT COMES 15 FT 6/3 SO INPUT CABLE.
AIRCO FOOT CONTROL
>NEW AW-WP2625-2 AIR COOLED TIG TORCH
GROUND CABLE AND CLAMP <
THIS UNIT HAS BEEN TESTED AND IS IN GOOD CONDITION. CUSTOMER TO PAY ACTUAL FREIGHT.
THIS UNIT HAS ALL THE ESSENTIAL FEATURES YOU NEED FOR HIGH-PRESICION AC TIG WELDING, PLUS THE FLEXIBILITY TO HANDLE A VARIETY OF METALS.
FOR DEMANDING ALUMINUM WORK, THE HELIWELDER V 250 HAS SQUAREWAVE AC OUTPUT
