Many filler metal manufacturers list a range in their catalogs for there filler metals. Some even have recommended setting for positions, etc. Lincoln electric publishes a book that contains a very good selection of parameters for welding with GMAW, FCAW, FCAW SS, SMAW, and GTAW. The book is called the "procedure handbook of arc welding". This in conjuction with your experience should give some good starting points. The lincoln book is very inexpensive and contains some very good information.
There are also .pdf documents available at Lincolns site at http://www.mylincolnelectric.com/Catalog/lecobrowse.asp which list the parameters for their filler metals. Esab also has a site but I couldn't connect to it tonight.
Good Day
http://www.weldinginspectionsvcs.com
Gerald Austin
