Up Topic Welding Industry / General Welding Discussion / Question About Reading Piping Isos
- - By ZCat (***) Date 09-25-2010 01:48
What's the correct way of reading the little triangles they put in to show which way a 45 points?
Parent - - By PipeIt (**) Date 09-25-2010 04:38
Anyway you can put an image on? 45's can be tricky to read on an Iso in a nut shell its either a change in up and down direction or side to side horizontal direction you call it a triangle which is correct, I call it a half square which is in a since a right triangle. I teach print reading to apprentices so I use the box/square example, I don't know how to post images on this site, I need to learn so I can hopefully help you.
Parent - By ZCat (***) Date 09-25-2010 04:51
I don't have a picture of one, just reading them at work and wondering.
