Hello
Which is the minimum thickness plate that AUTOMATIC VERTICAL UP machine could weld?
Recently the company has bought a koike VUPNA3-ST machine with NR-431 Lincoln process (EGW). We are interesting to evaluate if the machine could work fine in 0.25" plates for tank storage construction.
Thank you !
