Up Topic Welding Industry / Welding Fundamentals / An aluminum repair
- - By aevald (*****) Date 10-07-2010 14:46
Hello folks, I believe this topic has been discussed before, but not necessarily with a pictorial to accompany it. The other day the "kids" over in the diesel shop at our school decided to modify an intake manifold on one of their diesel engine trainers. Hence, the weld shop then becomes the rescuer. They busted a pretty good section out of one of the mounting hole passages. After looking it over I decided to use an old trick that was passed onto me by an "old timer", after some cleaning and prep. work, I inserted a stainless steel bolt into the hole and used it for a "form" to shape and maintain the passage while welding. I let them complete the job by drilling the hole back to size and concentricity and then spot-facing the repaired side. Here are a few pics to detail the process. Best regards, Allan
Parent - - By Ringo (***) Date 10-07-2010 15:18
Slick job man,I'll have to remember that one.Did you use 4043 or 5356?
Parent - - By aevald (*****) Date 10-07-2010 15:24
Hello Ringo, different folks have different trains of thought about which filler, in this case I used 5356 because it is slightly "harder" in the as welded state. 4043 could be used just as successfully IMHO. Best regards, Allan
Parent - By Ringo (***) Date 10-07-2010 16:35
I hear ya.I've had mixed results with welding cast.The first pass usually has alot of porosity,which I grind flush,then the rest usually goes pretty good.Nice job on your part.
Parent - By Milton Gravitt (***) Date 10-07-2010 15:19
It looks good Allan.
                  M.g.
Parent - - By jwright650 (*****) Date 10-07-2010 16:38
Nice work Allan.....always good to see your postings in "tricks of the trade" filled with pictures.
Parent - - By up-ten (***) Date 10-08-2010 03:06
Great work Allan and another trick to put down in the black book. I see a coffee cup in the background of that last pic, was there an inspector nearby?  chuckle. re: cactus's bar joke today.
Parent - - By aevald (*****) Date 10-08-2010 04:10
No up-ten, just a welding instructor, you know how we are! Unfortunately, nobody offered to buy me lunch. Best regards, Allan
Parent - By jwright650 (*****) Date 10-08-2010 10:25
[quote]nobody offered to buy me lunch[/quote]
Allan, you have to get there before 11:20 in case somebody is buying lunch.....LOL
Parent - - By 99205 (***) Date 10-08-2010 20:28
Hey now, lets easy up on us Inspectors. lol
Parent - By Tommyjoking (****) Date 10-08-2010 21:23
Good job Allen    that is one of those "slick as greased owl s**t" tricks.   It might be worth repeating that you used an SS bolt....do not try this with galvanized or cadmium coated bolts!
Parent - - By welderbrent (*****) Date 10-08-2010 22:10
Another great idea Allan.
I've used a lot of brass and copper round pieces to weld back broken areas of steel heavy equipment parts.  Had not considered using SS on Alum.
Have a Great Day,  Brent
Parent - By 803056 (*****) Date 10-10-2010 21:00
I like it!
That's using the "ol noggin."
