JS55 is on the money with regards to the formation of martensite in the partially melted zone at the weld interface.
Think of the carbon equivlency formulas. The elements considered by the CE formula includes Cr, Ni, Mn, Si, etc. Each contribute to the CE. The higher the CE, the more likely martensite will form. The truth of the matter is, there are several CE formulas, each provides a little different CE, but the results is the same, high CE indicates the weld or partially melted zone in the HAZ (against the molten weld puddle) will likely form martensite when cooled quickly. Considering the high percentage of Cr in the austenitic stainless, alloyed with the constiuents of the carbon steel filler metal, almost ensures martensite is going to be a problem.
