Up Topic Welding Industry / General Welding Discussion / TIG WELD BRASS TO STAINLESS
- - By waynecus Date 09-13-2002 21:02
HOW CAN CA-360 BRASS BE TIG WELDED TO 300 SERIES STAINLESS STEEL?
Parent - - By bzzzzzzzzzz (**) Date 09-13-2002 21:51
I'm no expert but I would think.. Braze,braze,braze. 56% silver content. if it gets really hot in use then....????????
Parent - By SEAPLANE (*) Date 09-15-2002 16:32
I have tig welded stainless nuts to brass with a rod that is commonly known as everdo. I don't know what the composition of the rod is, But it seems to be mostly brass. Maybe someone else can chime in with some more info, Or you can call your local weld supply for info.
Parent - - By Tim Buyle (**) Date 09-16-2002 07:14
Step 1 :
Butter layer on stainless steel : Nickel (ER Ni-1)
Step 2 :
another butter layer on previous : Monel type (ER NiCu-7)
Step 3 :
another 2 butter layers Cu70-Ni30 on previous
Step 4 :
the joint can now be made using ER CuAl
Parent - By bzzzzzzzzzz (**) Date 09-16-2002 10:19
hmmmm.. does the stainless ever actually reach melting point here?
