ROTFLMFAOAAA!!! :) :) :)
Hey John, use the 'Scotch-brite" pads and you should be fine... The only concern the client has is having the Chromium oxide layer on the surface (Blue-ish discoloration) being exposed for a prolonged period around the "elements/atmosphere" where this structure will be... So, in order to prevent any accelerated corrosion there, that layer needs to be removed to the degree where only a shiny metal surface is present and as a result, this will start to automatically passivate (forming a protective layer which will protect the Stainless steel underneath the surface from corrosion and further oxidation.) itself almost instantaneously without the aid of chemicals since it is a chemical reaction in itself. ;)
Now you may need a "chemical helper" (pickling/passivating agents) if the chromium oxide layer is thicker than usual and cannot be totally removed with the scotch-brite pads alone... Most reputable welding supply houses/distributors usually carry something that's relatively inexpensive should you need the "extra help. ;)"
Btw, did this client list any special instructions regarding this specific situation in the general notes??? Anywho, hope this helps. ;)
