Up Topic American Welding Society Services / Technical Standards & Publications / AWS D1.1-4.1.3.2-Tack welder qualification
- - By Nalla (***) Date 10-20-2010 12:07
Dear Friends
AWS D1.1Ed-2008-4.1.3.2-Period of Effectiveness
1) Code clearly says tack-welder's qualification valid indefinitely for the process and positions qualified for.
2) We also use "Low Levy 3G-SMAW-max. thk qualified is 10mm" qualified welders as tack-welders only. Their qualification also valid indefinitely for the process and position qualified for as long they perform as tack-welders only.
So does not require revalidation whatsoever
Pls advise if my understanding is correct
Thanks
Parent - By eekpod (****) Date 10-20-2010 14:00
Yes you are correct that the code does say that a "tack welder" is certified indefinately in the positions and processes in which they are qualified.
I have found it easier to still "re-certify" my tack welders every 6 months even though it is not required.  I do this only as a precaution on my part becasue I have SO many outside inspectors and engineers reviewing my certs and re-quals that I didn't want to get into an argument with them on this clause.
Is it above and beyond what is called for? yes, do I have to do it? no. But again I have people with different levels of knowledge of the code and instead of me teaching everyone about this stipulation, I decided to just go with the flow and re-certify them and document it every six months.
Now remember to "requalify" is easy.  It's just confirming and documenting that they are welding with the process and position they are qualified for, it's not an actual test.  I use welds off of the production floor to re-qual my guys and write it down and keep it in a file, not too hard, a little time consuming, the longest part is typing it up.  Note this is assuming the welds they put in are passing a visual inspection.
Good Luck
- - By 877412 (*) Date 11-01-2010 15:31
Sounds like eepod is maintaining a Welder's Continuity Record Log  which you need to do with all welders. If their welding skills are in question then requalification by test is mandated.
Parent - By eekpod (****) Date 11-03-2010 10:16
correct, I do keep a welders continuity log for my "tack" welders as well as my "regular" welders.
