I think it could go either way depending upon the heat input,the type of hardness test, and where in the HAZ you tested.
Without looking it up, since it isn't handy, I assume 252 is a larger grained material. So, if you used low heat input the HAZ will be normalized in which case you would realize more hardnss. If you used high heat input you would tend more towards annealing in which case it could be softer. If you used a MIC 10 you could end up in either types of zones. If you used a telebrineller and ground the weld to access the hte HAZ you would get a more homogeneous sample.
If you tested near the weld it would have a tendency to be different than the outer part of the HAZ.
NOTHING is more complicated than a HAZ.
