By stanantonio
Date 10-22-2010 05:24
Just think when you are gonna have to wear a hard hat with your hood. Its coming sooner than later. Welding engineers and safety engineers make this stuff a policy and never step outta there company truck on the ROW. You're just gonna have to deal with it I guess or just sit at the house. I don't know but I agree with you. I am not sure if they just try to factor in stupid idealogy or just try to make themselves busy makeing upper managment think there getting there money worth. By writing and impleminting new safety practices.
"Up Here" (Canada) we are required to have grinder guards with a minimum 120° Sweep on them, so all of my guards are cut down, and the edges of the guards are nicely rounded off to remove any sharp corners. Also, I use the newer Makita GA series of angle grinder with the quick release guards that are easy to reposition, and have a couple of older 9015DBZ with the quick release guards.
Now, primarily I do repair and manintenance work on a rental fleet of Oilfield Equipment... In the past, I have built Bed Trucks, Winch Tractos, Picker Trucks etc and even though I do not weld on pipelines for a living, I do repairs on 2" - 10" pipe at times at work.
For the life of me, I do not remember one single situation where I HAD to remove a grinder guard to get a job done. When I DID, it was because I was using the wrong grinder, or the wrong size of consumable... Now-a-days, I use a combination of 5" and 6" grinders for the simple fact that a fresh 6" disk will reach much farther than a fresh 5" will.
No disrespect to anyone is intended, I just do NOT understand why anyone would view an un-guarded angle grinder as "Safe"
For the record, I do not own a DeWalt grinder, so I have never seen the warning about the use of the guard on pipe.
