Hi,
We manufacture truck tank semi-trailer in aluminum. Our tanks are not ASME registered but we are bound by the tank code (DOT-406) to use welding process accepted by the ASME pressure vessel and boilers code.
Is hybrid laser-GMAW welding process accepted by the ASME code? Could a joint made with that process be considered being a multi-process joint (laser + GMAW)?
thank you,
AB
