True, I guess I was 'assuming' squares, flats, etc for industrial barriers not necessarily round for grip rails. Though I have used rounds for barriers as well. But as I see nothing about pipe in the OP and their other PQR tests were with plate, still an assumtion on my part.
But then, according to AISC defining of 'Structural', handrails are not part of structural. Not to say how NYC looks at them regardless of how the codes look at them. Also, it depends upon how heavy of wall thickness we are talking about. Most railings will be thin enough to be D1.3 not D1.1. That removes it even further from the 'Structural' definition according to AISC.
But, if your prints, specs, general notes, or NYC say that ALL welding will be done per D1.1, then 'ALL' MEANS 'ALL' THAT'S 'ALL' 'ALL' MEANS!!!
Have a Great Day, Brent
If the NYSSCM is invoked, D 1.1 cannot be used. The NYSDOT and the NYCDOT both make allowances for handrails and other non standard bridge components, such as round railings and Stainless Steel Railings.
Qualification to the NYSSCM is somewhat like qualifying to AWS D 1.5 (Bridge Code) The NYSSCM is more than a welding code, which does not resemble D1.1. Even resemblance of D1.5, to the D 1.1 is superficial. Things like AWS WPS pre-qualification and AWS Standard WPS's are a sad dream to the unwary contractor!
Almost all aspects of the contract operations in a DOT contract are subject to full time Third Party Inspection. The contractor is required to supply a Lockable office, phone, copier, fax machine, file cabinet, hanging file, and plan table and office desk for the inspector. Material traceability, shielding gas traceability and testing, fastener traceability and testing, and even material transfer and delivery, is closely regulated. Things like tack welds, temporary welds and arc strike remediation have strict requirements that the ordinary structural contractor does not believe, and cannot afford to deal with. Most "first time" DOT contractors are overwhelmed by the extensive nature of the requirements. I've recently saw a small shop owner cry when he could not and would not comply with the requirements. He didn't even have a copy of the NYSSCM, but he couldn't have read or understood it even if he had a copy!
There is money to be made in DOT work, but you have to know what you are doing, and quality requirements are job one.
Joe Kane
