This question is odd.
There really isn't anything I would call bainite steel that I know of, though the language seems to imply this from time to time(I use it myself), and it is a convenient catagorization. There are steels that typically result in a bainitic structure by intent, and sometimes not. But even these steels if you slow down the cooling will go to ferrite and in many cases if you speed up the cooling will go to martensite.
The common versions are the Grade 11, Grade 22 type Cr Mo's, and many of the HSLA's, but there are literally thousands.
