Up Topic Welding Industry / General Welding Discussion / Bending T1 flat bar 1/2" x 6"
- - By cwf07 (***) Date 10-30-2010 16:05
I am giving a price to rebuild the front of a log trailer. From the front where the glad hands are back 10', fifth wheel plate, king pin, bolsters, everything. I am making the I-beams out of T1. I am going to make the I- beams 16" and taper it down to 12". I am concern on how hard it is going to be to bend the bottom flange to make the taper. What do yall think is going to be the best way to do this?
Parent - - By Cactusthewelder (*****) Date 10-30-2010 22:58
Rosebud and a 16 lbs sledge along with a couple of bar clamps
Parent - - By cwf07 (***) Date 10-31-2010 00:13
Thanks for the info but I was looking for a way I didn't have to cuss as much, but I guess I could use it as stress relief. Its good I can build it up side down. Hope it goes good I start a big bridge beam job in a couple of weeks.
Parent - By 99205 (***) Date 10-31-2010 06:36
check the Tips and Tricks section on this forum.  I saw something in there that might help you out.
Parent - By weldwade (***) Date 10-30-2010 23:18
Yep heat it and hit with a BFH.
