Hi TK!
Are you sure you're talking about 1/2 " diameter - schedule 10 pipe??? What is the wall thickness of this pipe?
I ask this because schedule 10 pipe has a nominal wall thickness of .109"
What is the actual groove joint configuration??? Is the joint a "U" groove, or a "V" groove instead and if it is, then what would the radius be on each "J" groove if it is a "U' groove being welded together???
Al does make perfect sense to reduce the size of the root face to what he suggests in order to achieve consistent penetration along with the other suggestions given by Lawrence also. Al also hit the nail right on the head regarding cleanliness when welding Aluminum... Finally as Lawrence mentioned earlier, the joint configuration must be precisely prepared prior to welding since it is more critical with Aluminum than with steels. ;) Btw, what are your welding machine settings (Volts, Amps, type of tungsten&prep, gas flow rate, etc.)???
