By -
Date 06-29-2000 23:03
I need recommendations for a purge weld set up. The material is 14 ga. 316L stainless. The weld process is TIG.
The product is 8" and 10" round pipe and elbows. This is a pharmacutical application so the welds must be clean inside.
The fittings are plasma cut which means a less than perfect fit. I hope this is enough info.
