Up Topic Welding Industry / Technical Discussions / Steel tower-Inspection
- - By Mech.Engr Date 09-20-2002 02:34
A steel tower 300ft height is designed for supporting vent stack.Steel tower is designed by pipes having different schedules.What is the welding inspection critaria?
Saeed.
Parent - By CHGuilford (****) Date 09-20-2002 08:49
You should be able to find the inspection criteria in the applicable welding code. Your contract specifications will tell you which code you are dealing with.
CHGuilford
Parent - By G.S.Crisi (****) Date 09-20-2002 19:33
I agree with Mr. Guilford's opinion. I'd just add that, in lack of any welding inspection criteria set forth in the contract documents, and as a steel tower is to be considered as structural steel, you can follow AWS D.1.1 Code.
