Up Topic American Welding Society Services / AWS Learning & Education / welding on cars
- - By ljones6455 Date 11-04-2010 21:08
I have heard that it is not a good idea to weld on car frames unless you know the right process in doing it, if I was to do it, I would be using a miller 225
arc welder; So I need to know the right way to do it. I have already cleaned all surfaces,cut to lenght my peices, I am going to put a frame into the
existing frame to strenghten the front bumper horns. I have 6010 and 7018 rod at home will this work or ?
Parent - By nctremblay2279 Date 11-05-2010 13:18
You have the right power plant for the job... When welding a car frame its only tricky because of distortion so just be careful with the amount of heat you put in their.
- By Hector Garcia Date 11-04-2010 23:23
Welding on frames are very difficult.  the steel on the frame is very hard, high carbon.  Maybe someone will know the number electrode this is.
