Firstpass,
I would presume that a combination of welds could be achieved with these welder qualifications.
The two options used for the original tests plus :
Vertical down root with F3 - vertical up fill & cap with F4
Vertical up root with F4 - vertical down fill and cap with F3
Just remember - just because the WPS allows vertical up or vertical down doesn't mean the welder can follow suit.
The welder is still governed by the essential variables of the original welder qualification,
Hope that helps,
Regards,
Shane
