Although the question isn't clear, I'm assuming the OP was looking to add some brass to a casting, and not repair a broken part.
If that is the case, there is no good answer, as a silver braze will not give a good color match at all.
I suppose it could be build up with a braze, and sent out for plating, but this goes way past the "little favor" status of the job.
Anyway, GTAW probably isn't the best choice, but at least under the argon shield, IF you can avoid boiling off the zinc with the high temperature of TIG, you may end up with less polishing work to do. I tend to stick to O/A for brazing though.
