Up Topic Welders and Inspectors / Welding Equipment Classifieds / 2004 dodge ram 3500 parts
- - By raftergwelding (*****) Date 11-12-2010 08:03 Edited 11-12-2010 08:06
5.9l cummins motor with 149,00 miles on it the motor is tight never gave me any trouble just routine wear and tear stuff i have called junk yards and got prices they range anywhere from 6500-7500 with over 150,000 on them ill sell mine for 6,000 OBO
2 left side doors:200.00 ea obo they have electric windows and locks
1 right rear door 200.00 electric as well
1 left front fender 100.00
1 left fron head light assy. 100.00
draw tight removaball g/n hitch 250.00 with mounting hardware
i have a black hood for 150.00 (600.00 new)
grille bracket for 65.00
6spd manual shift tranny these go for 2,000 in a junk yard ill sell it for 1,000 again never any issues with this either
dual wheel rear end 3.73 gear ratio these are going for around 1500.00   1,000.00
Interior is balck with cloth seats all the interior i will sell as a set for 1,000 or i can piece it out and the prices will vary
and lastly my super chips programmer it works on cummins motor 02-06 i always ran it in fuel saver never in performance let me know what yall need and we can beging the haggeling process
oh yeah i have 5 tires and wheels the tires are 17'' toyos on the back i put them on in june i think it was they cost me 800 for the 4 tir3e with rims 150 each
i took the factory radio out to install my system but still have it its a tape player make me an offer on it
Parent - - By dg09 (**) Date 11-12-2010 19:11
What happened??? Did you wreck it?   I got an 04 too I may need some stuff.  Gotta check though.
Parent - - By dg09 (**) Date 11-13-2010 04:22
What kind of mileage did you get with the programmer?   Might be inerested in it
Parent - By raftergwelding (*****) Date 11-14-2010 22:09
19 LOADED OR EMPTY
Parent - - By Cactusthewelder (*****) Date 11-12-2010 21:52
I need some Valve stem caps. Got any of them ? How about any slightly used Light Pole dents ? I know you have to have one of those !  Call me
Parent - By raftergwelding (*****) Date 11-14-2010 22:11
the valve stem caps are gold pated and wont be cheap lmao
Parent - - By Cumminsguy71 (*****) Date 11-13-2010 11:46
Is this your rig Shad? What happened?
Parent - - By raftergwelding (*****) Date 11-14-2010 22:09
It was my rig i hit a gaurd rail sending a text
Parent - By Chris2626 (***) Date 11-15-2010 05:19
I heard on the news that 5,474 people died last year sending txt messages. I don't understand why people are going back to morse code whats up with that??
- - By JLWelding (***) Date 11-12-2010 23:41 Edited 11-12-2010 23:44
What happen?
Go to the Dodge Cummins Fourm and register, put items up and get ready the calls will fly in at those prices. Belive me the calls wont stop till you pull it.
Parent - - By dg09 (**) Date 11-13-2010 04:32
Oh are the tires pretty decent?
Parent - By raftergwelding (*****) Date 11-14-2010 22:10
the 4 on the back are very good 17'' toyos
Parent - - By raftergwelding (*****) Date 11-16-2010 04:12
Thanks joe suppose to have a guy sending money for the mirrors no phone calls yet but lots of replys we'll see how it goes. You seen any cheap duallys up there for sale i need an ext cab or a quad cab
Parent - - By JLWelding (***) Date 11-17-2010 00:35
Right down the road from me is a 04 extend, it said 10k on the window with 150k. you wont the phone #?
Parent - - By raftergwelding (*****) Date 11-17-2010 14:47
dont have that much i gotta pay cash this time credit is screwed from hospital bills and i still owe on this 1 it really sucks
Parent - - By JLWelding (***) Date 11-18-2010 02:19
I here ya man, I am trying to find away to buy another 00 or 02 dully that my parts will work on. My eng. is just about shot, all new parts on the outside of eng. I mean everything is new. It sucks right now. I have work this week but may go another with no work. Wish your eng would work.
Parent - - By raftergwelding (*****) Date 11-18-2010 15:01
i dont see why it wouldnt it is the 5.9 cummins all you might need is the computer for my motor and ill throw that in too
Parent - - By JLWelding (***) Date 11-19-2010 00:00
I will check into it. Maybe Shawn on here could tell us something. How bout it Shawn whats your thought?
Parent - - By weldwade (***) Date 11-19-2010 00:47 Edited 11-19-2010 01:49
Yes it will work, get the computer, engine wiring harness and you will have no problems. Very easy swap!
Parent - - By JeremyW83 (***) Date 11-19-2010 01:12
Youll need both computers and then it still might not work.  you might have issuse getting to pcm to work with all the other sensors on your truck to work together.  Im sure it can be done but might want to see if there is a mechanic that specializes in Dodge Cummins trucks.
Shad there is a 98 to 02 regular cab 4x4 dually down in corsicana, tx with a flatbed on it.
Parent - - By raftergwelding (*****) Date 11-19-2010 19:34
Thanks Jeremy but theres no leg room in a single cab
Parent - By DaveBoyer (*****) Date 11-20-2010 01:33
That is only because You are a foot too tall.
Parent - - By Cumminsguy71 (*****) Date 12-04-2010 23:26
Joe, I'm thinking Jeremy is right. Your pcm on the truck probably won't work with the new ecm on Shad's Cummins, most likely different programming or some sort of thing. Taking his pcm, ecm, engine and harness might work but as Jeremy said other sensors on your truck may not work, i.e, wheel speed in the rear axle, tranny senors if any and then there is the abs. Depending on the year I'm thinking his could be a common rail, seems like they did that thing again with the half year model. 2004 with injection pump and injectors, 2004.5 with cp3 and common rail, not 100% sure about that though but thinking it's correct. You could probably get with some folks like Geno's garage or Sheid diesel and start the question asking. These folks are pretty deep into Cummins and Dodge and would most likely be able to give you a better answer.
http://www.scheiddiesel.com/user_pages/home_0.shtml?page=Home
http://www.genosgarage.com/
Parent - By raftergwelding (*****) Date 12-09-2010 09:00
my motr has everything but the harnes sold it yeqateray to guy and ot wont work on his truck
Parent - By texasrigwelder (**) Date 12-13-2010 04:12
03 up is common rail. 04.5 the change to kinda like high output like they did in 01  it all really has to do with emissions the block will work for 89 to 07 I have been told
Parent - - By raftergwelding (*****) Date 11-19-2010 19:36
I listed the truck on that website and so far nothing but a bunch of damn tire kickers that want something for nothing ill keep making the payments before i give the parts away
Parent - - By JLWelding (***) Date 11-20-2010 01:55
There is (The Diesel Garage), (Competion Diesel),and Mopar1973Man Fourm one of them might sale. The last time I sold anything on the cummins fourm the calls never stoped.
Parent - - By raftergwelding (*****) Date 11-20-2010 05:58
i got your call but i dont hves truckto go eork in right now thanks
Parent - - By JeremyW83 (***) Date 11-20-2010 20:40
Where are you working now.  Still in SA or near Shreveport with Cactus.
Parent - - By raftergwelding (*****) Date 11-22-2010 04:45
im at that coal mine gig i got almost ready to drag
Parent - - By JeremyW83 (***) Date 12-02-2010 02:18
Any luck finding another truck yet shad?  I am keeping my eyes open for ya up here in NTX.
Parent - By Pickupman (***) Date 12-02-2010 02:41
I saw a 92 Dodge dually, 5 spd, cummins, regular cab, with a pickup box still on it for $5995 in a car trader magazine. I think it was a 2wd though. Just glanced at it. If anyone is interested let me know I'll get you a phone #. Tom
Parent - By raftergwelding (*****) Date 12-02-2010 06:01
No Jeremy no luck yet i need something quick im trying to get out of here by the end of next week if all else fails i pull a trailer with my moms half ton
