By Mat
Date 11-18-2010 03:17
Edited 11-18-2010 03:29
I actually just picked up two air hose reels for 134 bucks total from princess Auto that will make skookum cable reels! They hold 100' of 3/8" air hose so likewise will hold at least 100' of welding cable! One of the company skids at work was built from the reels and modified so that the cables wouldn't need to be disconnected from the machine to roll them out.
I have a question about your setup, why is your stinger and ground connected directly to the cables on your spools without a connector? In the event that you can't get close to where you are working with your truck, how will you add more lengths of cable? There is no bigger piss off then to pull all of your cable out, only to realize that "Well bugger, I'm a foot short of reaching that joint!"
A simple Handle could be made out of a short length of pipe with an ID that matches the internal rod. You could even knurl it to add to the appearance. Elsewise you could make a wood handle out of hardwood which would contrast the reels quite nicely.
