Hi TJohnson, and
"WELDCOME TO THE WORLD'S GREATEST WELDING FORUM!!! :) :) :)"You still have not revealed to us the AWS classification of the FCAW electrode... Do you understand what this means as a question that is important to eliminating all of the possible causes for your defective welds?
In other words, Al, "803056" is most definitely correct (None better in here to point out such nuances IMHO!) in stating his puzzlement as to why you did not include the AWS Electrode classification for the type of FCAW filler metal you are currently using... So, if you are using for example a E 70 T X-X ( the zero after the number seven indicates welding position which is flat and horizontal only) filler metal as opposed to an E 71 T X-X (The number one after the number seven indicates all position deposits), then you're using the correct filler metal for the 1F position... Btw, the number seven represents the tensile strength of the filler metal being used...
However, if you are using an all position filler metal such as an E 71 T X-X wire, then you may not have your machine settings optimally set for that type of filler metal especially from a penetration perspective, and would be better suited to use the proper recommended FCAW filler metal specifically designed for that particular position.
Now another important question would be to verify if the WPS (Welding Procedure Specification) states what is the specific type of FCAW filler metal to use for this test...
So you may want get that aspect clarified also... Other than that, you have been given some sound advice by the others who posted also. Best of luck to you. ;)
