Thank you very much for replying to my post Lawrence. Well I agree with you on the part about doing it over because I can do better, I think they are harder on me because they know I have a little skill and can do better. Heres the class situation, 27 students, 16 weeks to pass the course if you want to go to the advanced pipe class, which I do. Most of the students have never even seen a TIG rig before. I have used a TIG about 3 times for a total of about 10 beads and none walking the cup. First you do pad of beads all overlaping four beads in total, in all four positions, flat, horizontal, vert. overhead. Then T joint in four positions, then lap joint four positions, then open root four positions, and finally open root with backing plate four positions. Ok sounds like alot right, well theres more, the other part of the course is stick welding so you have to do all that stuff I just mentioned with a 6010 rod, sounds like alot right, well theres more, after the 6010 rod you have to do all the things mention before with a 7018 rod, well except the open root stuff that s 6010 root with 7018 on out, backing strip and no strip. Wow this is the first time I have seen all this on paper and it looks like alot. But maybe not to an experienced welder, but that I am not. I started the class on the 27 of Sept. and I am on open root in both TIG and stick, so I am doing pretty good. Some of the guys are still on pad of beads. I do understand why they make thier dicisions on pass or fail but this one was really close and I will take your advice and ask about the specs before I do it next time.
