Up Topic Welding Industry / Technical Discussions / Welding to Existing Steel Beams
- - By pcarlson Date 11-24-2010 21:07
I have read 2 documents by David Ricker (Field Welding to Existing Steel Structures) and R.H.R Tide (Reinforcing Steel Members and the effects of welding).  The conclusion is that stress reduction is still unclear.  One of the recommendations is use a maximum of 3ksi when welding to a beam (this article is 20 years old).  My condition is welding a WT to the bottom flange of an existing WF beam, and am trying to determine the reduced stress to decide whether or not shoring is required.  Does anyone know of anything more current than the articles noted above for additional research?  Thanks.
Pete
Parent - - By swnorris (****) Date 11-25-2010 15:38
Pete,
Take a look at AWS D1.1 Section 8, Strengthening and Repair of Existing Structures.  This section contains basic information pertinent
to the welded modification or repair of existing steel structures.
Parent - By 803056 (*****) Date 11-28-2010 18:23
The fundamentals of good engineering have not changed much in the last twenty years. Dave Ricker was an engineer with a company I worked for as an apprentice Ironworker and again as a Journeyman Ironworker. The company was and still is involved with both new construction and the repair and strengthening of existing structures. He wrote a number of articles on the subject of structural steel design and has a well-earned reputation in the structural steel industry. Any article he wrote was based on his experience in design and fieldwork and the information is as valid now as it was when he wrote it.
The concept he is addressing is that you need to unload the existing structural member as much as practical to reduce or mitigate the chance of a structural failure and unexpected distortion during the welding of new steel to the existing steel. In most cases this would require the use of falsework and jacks to reduce the loads to the level suggested. Rarely is a main member in an existing structure not subject to dead loads. If there were no dead (or live) loads to contend with, there would be no need to have a structural member there to begin with. The allowable stress permitted by the design code and the magnitude of the load determines what size member is necessary. It is usually the practice to size the structural member so that it is loaded to near its allowable stress level. If steel was free, that might not be the case, but the reality is that no one wants to pay for larger structural members than necessary. Assuming the member is loaded to the maximum permitted means that it will have to be supported by temporary supports while reinforcement or replacement structure is added.
