Up Topic Welding Industry / General Welding Discussion / Preferred Engine Driven welder
- - By ReedWelding Date 11-29-2010 05:20
Ok.. guys here is whats up, i've got an itch for a Engine driven welder miller or lincoln (preferred miller). I'm looking for a minimum of 90 OCV, what do you all prefer on this matter.
Thanks,
-Steve
Parent - By Cactusthewelder (*****) Date 11-29-2010 15:57
Vantage 500 Compact. Nothing else on the Market will even come close in Comparison
Parent - By weldwade (***) Date 11-30-2010 19:30
It all depends on what you are wanting or needing to do with the machine? Not enough info on what you want it to do for you. Do you need a multiprocess machine with single and three phase auxzillary power? How much DC/AC output do you need? What kind of welding are you doing or wanting to do with a new machine? Dont worry about OCV get a machine that has an adjustable "hot start" "dig" "inductance" etc that allows you to custom taylor your volt/amp curve to the situation you are welding in, this will give you what you are looking for in OCV's and you wont be stuck in one curve for everything.
My top pick for a Miller machine would be the BB PipePro 350 or the BB AirPak depending on need?
http://www.millerwelds.com/products/enginedriven/big_blue_350_pipe_pro/
http://www.millerwelds.com/products/enginedriven/big_blue_air_pak/
If you need something that has the most bang for the buck and don't mind noise and high RPM get a Trailblazer 302
http://www.millerwelds.com/products/enginedriven/trailblazer_302/
If you want exceptional arc performance in DC CC/CV buy and XMT 304 CC/CV or XMT 350 MPa and combine it with a Miller or Lincoln engine drive with at least 10,000Watts of aux power.
http://www.millerwelds.com/products/multiprocess/xmt_304_cc_cv/
http://www.millerwelds.com/products/multiprocess/xmt_350/
Lincoln would be the Vantage 500 Compact or 300D Perkins
http://www.mylincolnelectric.com/Catalog/equipmentdatasheet.aspx?p=62121
http://www.mylincolnelectric.com/Catalog/equipmentdatasheet.aspx?p=60861
These are my picks on what I would buy but I am willing to bet my needs and wants are very different from yours!
- - By Sberry (***) Date 11-29-2010 14:10
There are so many and they are often chosen because they are job or work type specific. Of all the numbers to pull out what makes the ocv so special?
Parent - By jwright650 (*****) Date 11-29-2010 14:41
Some of the 7018's are tough to light off with low OCV.
- By Sberry (***) Date 11-29-2010 15:31
I agree it can or could be a factor its just generally a number that doesn't come up until after some other issues normally do, maybe he knows more about it than the first thread in this post leads us to assume? Usually posts that vague consider machine size, amps output, type of work first, etc. Ocv doesn't usually come up until we get to advanced specs.
- - By Sberry (***) Date 11-29-2010 19:36 Edited 11-29-2010 19:48
I would have to agree with Cactus that it is about the ultimate machine, not sure if I was just scratching an itch I would be looking at a unit that sells for 14 large?
  I think the ocv is fairly low on those anyway??? I do like the VRD feature, nice if working in a wet crap  hole.
  The little Maxstar has that on it too, nice, no pokes even with wet gloves. If you are really looking for it the restarts are not quite as good, but its really minor and one has to be paying attn to even notice it.
Parent - - By FixaLinc (****) Date 11-29-2010 20:45
The newest Vantage has a hot start feature added now suppose to made them better than the first ones.  That is a big complaint about the early ones.
Parent - - By raftergwelding (*****) Date 11-29-2010 23:58
redface 200 or the green light 200
Parent - - By Johnny Walker (***) Date 11-30-2010 04:36
Vantage 300
Parent - - By hillbilly (**) Date 11-30-2010 04:51
I'm partial to the Red machines, but I've never owned a new engine drive. I'd have to give the Blue machines a chance, if I was to buy a new one tomorrow. The reason being is the customer service between the two. Miller's has been superb, pertaining to what products I have purchased of theirs. I wish I could say the same for Lincoln. Your results may vary. Lol.
Parent - By TozziWelding (**) Date 11-30-2010 20:42
I have a Trailblazer 301G on the truck that I use for most everything and I like it(bought it new when I started out), I also have an SA-250 that I pull out when I know I will be welding pipe all day, or doing bull work, the little Miller just cant keep up with the old hoss. When I go for a new machine probably in the spring it is going to be a Vantage 500 compact.
