!! There never seems to be black and white when dealing with AWS D1.1!!
Since you have outlined the situation and people that you are dealing with...have you pre-qualifyed the joint by RT or UT? Compared to the "labor" of sorting this problem out this would give substantial data to support the process development and cost is very reasonable!!
This would be very "black and white". No pun intended!
I did not read your post well. My review of "prequalified" open root was based on 3.13.3 (2) and I missed T, K and Y.
I still believe, however, based on table 4.5 that a deletion of a process from the WPS would require requalification. Table 4.5 applies essential varibles to singular process welds. This instance would , in essence change items 1,2,3 of 3.6.
Hope I have helped. D1.1 is complex and I network with others often.
