I believe Lawrence hit the the nail right on it's proverbial head because of the typical layout with the equipment found on "automatic" or mechanized GTAW "packaged" systems...
In other words, there is a difference in how this type of equipment performs when compared to most "semi-automatic" GTAW systems whereby an unmounted and separate wire feed mechanism is used and therefore increase the potential for the wire conduit to move enough to cause an unstable, inconsistent wire feed rate even with a relatively short conduit length usually found on GMAW feeders for Aluminum use...
However, I do agree that it is prudent to make sure one is getting the proper grip & tension on the wire from the drive rolls and that the proper rolls are being used for the type of metal wire.
If this is a system that has been purchased as a packaged system, then the manufacturer of this system would be able to give you the optimal recommendations for what pairing of drive rolls to use with a specific type of filler metal being used... If this is a system that was put together from a variety of different components, then I would suggest that one stick to the recommendations being given for welding aluminum by the specific type of wire feeder being used. ;)
