Finally, a question I can help with. Here are a couple of sources for spark test charts. As a blacksmith I often end up with some chunk of metal that looks like mild steel but can be some strange stuff. A spark test sometimes helps in at least distinguishing between higher/lower carbon content but is not definative in determining alloy. Bill's suggestion about comparing the spark stream against a known metal's stream is very helpful. Try to maintain the same pressure against the wheel for each piece.
Modern Welding by Althouse et al. 1980 ed. pg 610, but I would guess the more recent editions would have it also. It is an expensive book now but libraries often have it.
Decorative and Sculptural Ironwork by Dona Z. Meilach, 1977, pg 65. This chart is actually courtesy of Hobart Brothers. The chart also includes other tests e.g. fracture, chisel, flame etc. Again, you may find this in libraries.
Often, blacksmithing books have these charts. If I can help further, let me know.
Hope this helps.
Ken
