Depends upon what you mean by conditions. If you provide the same conditions (wire size, travel speed, current type, etc.) there won't be any equational heat input difference and there won't be enough real heat input difference to worry about.
The real issue for different processes is that conditions are seldom the same. And its the conditional differences you take advantage of.
