I need some help me setting up a BobCat 250 miller (as a power sourse) and High Freciuency unit......for 220 amp?
I am working in a chooper prototype frame, the owner of this project told me(and insisting) i have to use a 220 electrical power, in order to obtain a good penetration
for 1 1/4 solid bar motor frame.... by experience I know, if i set up the High Frecuency to Higher Amperage i will obtain a heat enough for a good penetratiion .....
to explain him i went to the specifications of both machines:
BobCat 250 Miller
http://www.millerwelds.com/products/enginedriven/product.php?model=M00185HF-251D-1 High-Frecuency arc starter and stabilizer
http://www.millerwelds.com/pdf/spec_sheets/AY5-0.pdfwhere you can see the output of the Bobcat range between 250, 275 amp at 25 Volts and duty cycle 60%, 100%
The HF Unit shows an input 115 VAC With an output of 250 Amp
You guys can help me, in how to explain him, that i will have enough penetration for the frame,? or i will need a bigger cable between the power sourse to the HF?
ALL THE CONNECTION ARE RIGHT BETWEEN MACHINES, BUT HE INSIST I HAVE TO USE 220 Amp..............OR I AM MISSING SOMETHING????
make me confuse too, couse the outlet in the welding machine for the grinders shows 120 amp, and i plug the HF in one of them...
Thank you for your help!!
Fred
New Jersey
