Hey guys,
I had an interesting job come in on the weekend with a customer needing some copper tubing(1/2"OD x .062wall) "welded". They were simple cross joints of the outside of the tubes he has bent into artistic configurations. He makes decorative artwork with the taxidermy mountings he creates. Anyway, after discussing the parameters of "welding" copper, I managed to convince him to simply sil-sol this particular project as he needed it asap. The job came out quite nicely as he was satisfied, although asked me if I could research copper welding via autogenous welding or using a Cu filler. I have ER CuSi bronze MIG wire & ER Cu MIG wire which is deoxidized wire. He indicated he would really like to maintain the copper color & the copper filler would be more aesthetic for his needs as many of his works are displayed in craft/art shows. I did explain the cost variances & would do some homework.
Ok, my query is if any of you familiar with copper fusion could recommend a procedure to use the ER Cu w/MIG & I am considering either Ar or Ar/mix. Since these are thin-walled tubings, which application would you favor & gas/mix? He also asked if a filler such as 8-10ga copper wire could be used & I kinda felt it may not be conducive to "welding" as it is not deoxidized. I have 250A of MIG power available & spoolguns. Ok.... I'm listening. Thanks......
Denny
