I think you would be hard pressed to find any corners being cut. It sounds like to me, once again, that there are some who are upset that they are not, and can not, get on this job. If you are not happy with the Wages you make then Buy a Rig and get on your own. Be your own man and make your own rules. As long as you work as an Employee, You are and will always be at the Mercy of someone else,.
