I've seen a horizontal dashed line on some drawings that we have recently been involved in. It was on drawings from Europe. It might be a European welding symbol. Try searching the web and perhaps this website:
http://www.royweb.ic24.net/Useful_Tables/Drawing/Weld.html
Good luck, Sean
Thanx Sean, that web site was just what I was looking for. Funny thing though is that the drawing is not a European Dwg. so some smart ass detailer just wanted to mess with someone's head, I think.
Is the arrow attached to the reference line pointing to a groove joint, and assuming this is a groove joint, indicating grinding or finishing the weld flush?
No, not a grind symbol. Just a dashed line running the length of the reference line.
It sounds like you have some European welding symbols. Is the drawing from a European country or company? Unfortuneately, I cant give you a good website on this one. The dashed line, if it is on the other side of the reference line from the symbol, is indicating an "arrow side" weld. A dashed line on the same side as the symbol indicates that it is a "other side" weld. The Eurpoean symbol system is very different from the AWS, and I personally find it much more difficult than the AWS system. These symbols are covered by ISO Standard 2553.
ISO 2553 = EN 22553 is under revision and the dashed line may go away. BUT consider the dashed lien as being the hidden line in a technical drawing and anything that is placed on this is on the hidden side or "other side" to which the arrow points. The solid line is what is visisble and thus is the "arow side". Other than this, there is little that is different in ISO 2553 to AWS A2.4 - I am the Secretary of the group revising ISO 2553 and trying to get more AWS A2.4 in it. For more information e-mail me at adavis@aws.org
