In the Coal Mine, we had no procedure, it was "we've always done it this way and it works"..On a similar configuration and materials it would have been a Double "V" 60* included angle, 400F preheat, SMAW E309-15, no PWHT.
This was for high impact and abrasion service, i.e. dragline and shovel bucket leading edge (MN) to (T1) disposable floor liner.
It is T-1 for abrasion resistance. I would use MIG proces, 1.2mm wire.
Would you prefer ER307 or ER309 welding wire in disimillar steel combination and why?
Thanks
T 309 is generally OK - Type 307 is material for walding Armor Plate
We had a place that carried that stuff as it was an OK popular rod for welding armor plate
309 is a sort of a "Magic wire" due to it's high Nickel content..multi purpose as it were. I have even used it on cast iron repairs.
309L electrode will work. 308L or 312 would be better. Manganese steel will precipitate carbides and crack if the interpass temperature isn't controlled. Because of that, the preheat and interpass temperatures should be kept to a minimum. I always used 300 deg. F maximum interpass as a rule of thumb for manganese but you can probably go up to 400 deg. F. as long as you monitor the interpass and keep it at or below this temperature. Shouldn't be too hard at the thickness you are welding.
Note that the preheat and interpass for T-1 also should not be any higher than 400 deg. F, if the joint is highly restrained and 200 deg. F. if it isn't. This is to avoid losing strength along the weld joint by exceeding the original T-1 tempering temperature.
Probably, at the thickness you are working with, the heat input doesn't need to be monitored as long as you use a process like SMAW or FCAW for the welding. You could probably also get away with SAW with a 1/8" wire. For me, the thickness is too high to recommend GMAW. I agree the double Vee joint type is preferable since you want to keep the total amount of weld to a minimum.
If localized hardness or strength of the T-1 is an issue, it's always best to run a test weld and do the appropriate mechanical and hardness tests.
Regards...
