Please comment if you can, thanks in advance.
Not sure if I’m putting this in the correct area of the forum.
Center weld impact results, why are FCAW so much less than other processes?
This has turned into more of an experiment than anything else.
Base material is 2” SA-387 grade 11 class 2. 2” (1.25 Cr / 0.5 Mo)
All test plates PWHT @1275°F for 5 hours.
Preheat interpass maintained until welding completed at 300°F – 500°F.
PQR for ASME Sections IX and VIII
Requirement: 20 ft/lbs. @ 15°F (FCAW wire manufacturers said they could not meet this requirement) I wanted to try it anyway.
I haven’t listed any weld parameters, as there maybe someone that may know that this process is just not correct for this situation.
4 processes tested, all weld materials advertised as for use on 1.25 Cr / .5 Mo, but none advertised with what to expect if impact tested.
FCAW 1/16” E81T1-B2C H8 (Co2)
The only thing that failed was FCAW in the center weld specimen. 3 specimens were 6 ft/lbs.
Both HAZs easily passed along with bends, tensiles ect.
Other processes that passed all requirements were, and I’ll only list the all weld impact #s:
SMAW passed at an average of 88
SAW passed at an average of 123
GTAW passed at an average of 299
So, over all of the processes, I have a range from 6 to 299. That’s a lot.
Any ideas?
