When welding steel, the minimum temperature is around 1600°C. This is approximately the temperature at which steel melts.
I do however believe that you are not looking for the welding temperature, but probably the pre-heat temperature. Am I right? If so, we need some more info like:
1) What material?
2) How thick?
3) What welding process and filler?
4) What service? (e.g. fatigue, Stress corrosion cracking service, Impact service)
5) Is the question aimed at the interpretation of code requirements? If it is, what code?
6) Is the question aimed at preventing hydrogen cracking?
We really need more info to answer this question.
Niekie
