Up Topic Welding Industry / General Welding Discussion / Using a small United Kingom TIG in U.S.
- - By Tim B Date 02-09-2011 21:17
I am going to see a small Clarke Mig that is practically being given away.  It is a machine that was sold in the U.K.
My undertanding is domestic electricity in the UK is 240 V at 50 Hz.
Our supply will be 230 to 240 Volts but at 60Hz.
My gut says a small jump in a low AC frequency won't matter either in welding qualities or saftey, but i am looking for other opinions.
Thanks,
Tim
Parent - By Lawrence (*****) Date 02-10-2011 00:26
I bet the owners manual is online...  Check it out first!
Parent - By fschweighardt (***) Date 02-10-2011 17:00
TIG in the title, MIG in the body of the post,  Which one is it.  Not that it makes a gob if difference, but would need to understand more about the guts of the machine.  If is an inverter MIG, it might mean something very different than a transformer TIG.  AC? DC? both?
Parent - By DaveBoyer (*****) Date 02-11-2011 03:20
If it is a transformer machine it won't matter. If an inverter, it would be worth checking, but most likely it will work.
