By Scamperator
Date 02-10-2011 13:06
Edited 02-14-2011 13:10
(GMAW process .045" Metalcore wire)(AWS D1.1)
Welding in a 1G position, in a T configuration (turn the T on its side and that is the joint in question), the Vertical parent metal extends approx. 8" above the joint to be welded and the other parent metal extends horizontaly several feet from the joint. The vertical member is 4" thick and the horizontal is 1/2" thick. Because of lack of access to the "other" side, there is a 1/4" backing bar placed first to the vertical member with 1/4" extending from the tip of the 45 degree bevel that is placed on the vertical member for a single bevel full pin joint config. Now the question is, if we pre-weld a root pass joining the backing bar to the parent metal (at the edge of the bevel), and THEN place the Horizontal member against the backing bar and tack into place, then weld a second root pass joinint the backing bar to the vertical member, and then finish out the bevel with the necessary hot passes, IS the first root pass we place considered part of the horizontal member now and we then need another 3/16" root opening beyond the toe of that, OR is the first root pass just considered pre-welding a portion of the joint before it is assembled?
The reason for doing the pre-pass is because of the gun angle not being sufficient enough with the restriction from the vertical member extending above the joint.
SHORT VERSION........Without writing some strange confusing weld procedure, can a part of a weld be added to the joint prior to the joint design being completed? I imagine this can be addressed in a weld symbol, but by doing this would it be violating a Pre-Qualified weld procedure.
Im curious to hear the answer too, but my take is that it would be seen as having a 3/8" root gap (assuming the leg of the first weld on the backer is 3/16", and the subsequent opening when fit together is 3/16") If that is that case, then it would violate the prequalified joint that you are working to.
What position is that 1st bead going to be welded in? If it is to be made with the vertical member in position then you might have bigger issues trying to make the metal core bead stay on the backer, Its not meant to be run horizontal.
