Up Topic Welding Industry / Inspection & Qualification / API 650 RT Requirements
- - By qaqcmpm (*) Date 02-14-2011 08:42
Qn: 1) I am reviewing RT films of a tank acc to API 650, it says 6.1.2.2
"..........one additional spot radiograph shall be taken in each additional 30 m (100 ft) (approximately) and any remaining major fraction of vertical joint of the same type and thickness."
So have I to consider the circumferential seam length also for this 30m weld length or only the verical joint length is sufficient. The tank is a vertical one & thk is 6mm.
Qn: 2) If the bottom plates are welded (Butt Joint), 10% of random RT applicable to that weld?
Parent - - By Shane Feder (****) Date 02-14-2011 12:07
qaqcmpm,
How can you be reviewing RT films if you are not familiar with the code ?
If you are passing judgement on someone or something you must be in possesion of all the facts.
Get the code and read it.
The answer to your first question is in the clause following the one you quoted.
6.1.2.3
One spot radiograph shall be taken in the first 3 m
(10 ft) of completed horizontal butt joint of the same type and
thickness (based on the thickness of the thinner plate at the
joint) without regard to the number of welders or welding
operators. Thereafter, one radiograph shall be taken in each
additional 60 m (200 ft) (approximately) and any remaining
major fraction of horizontal joint of the same type and thickness.
These radiographs are in addition to the radiographs of
junctions of vertical joints required by item c of 6.1.2.2 (see
Figure 6-1).
Second question took even less time to locate.
Try it yourself, go to 5.3.3 Examination and Testing of Tank Bottoms
I/we do not might giving assistance on this forum but you must make an effort to find the answers yourself, not jump on here and get us to do the work for you.
Sorry for the rant.
Regards,
Shane
Parent - - By Joey (***) Date 02-14-2011 14:57
Hi Shane
Your response is "Ayos" amigo :) :)
Joey
Parent - By Shane Feder (****) Date 02-15-2011 00:23
Maraming salamat po Joey
Parent - By dbigkahunna (****) Date 02-14-2011 23:35
The tank has already been built and you are reviewing the film?
The contractor that built the tank should have provided a shot sheet for the tank. You check it against what 650 requires.
It it not hard to calculate how many shot to take. D X pi (3.14) will give you the footage.
Guys with less than a high school education can calculate these.
