Posting is for a friend that is selling his Red D Arc machine. It is the Stainless Package. 4200Hrs and is asking $6000.00. If you have any further questions you can reach him at 619-855-1222.
Description:
The D302K 3+12 is a 300 amp @ 60% duty cycle, constant current, constant voltage, DC diesel engine-driven welder with 12,000 watts peak and 10,000 watts continuous 120/240 VAC auxiliary power. Its high-efficiency, three-phase welding generator requires less fuel and has enough power for gouging with up to 1/4" carbons. Output adjustment is via a potentiometer-type, full-range, Amperage/Voltage Adjust Control and a six-range Process/Contactor Control switch which includes four arc drive (dig) settings in Stick mode. Remote contactor control, as well as remote amperage and voltage control, are via 3-pin and 14-pin MS style receptacles mounted on the front control panel.
Engine:
Kubota V1505-E2BG1, Tier 2, liquid-cooled, four cylinder, 20.2 HP @ 1800 rpm, 92 cu.in. with automatic engine shutdown.
