We are manufacturing a welding system using a Yb:YAG disk laser (1030 nm, 7KW max. output) to weld small aluminum parts. We have added a viewing window to the light tight enclosure that will accomodate near infrared laser beam but I have concerns that we have not addressed the other hazards associated with the welding process (UV, light intensity, etc.). We would like to put an addition filter glass over the laser rated viewing window but I am not sure how to spec it. Can anyone help me with the welding hazards with which I should be concerned and the standard to which I should refer to justify the selection of the filter?
